Thread: Two db8e's
Old 13-Jan-2016, 12:43 AM   #8
As you can see my channel are spread out, any suggestions? What other info do you need?
I already did an analysis for you.
http://forum.tvfool.com/showthread.php?t=15804
and your tvfool report still looks as bad now as it did then. You have a lot of weak channels in many directions.
What you need is something like this:
If you insist on sticking with two DB8es, this is about all you can expect:
DB8e No. 1 aimed at 278 degrees magnetic
WCDC ABC, real channel 36
DB8e No. 2 aimed at 347 degrees magnetic
WVTA PBS, real channel 24
WNNE NBC, real channel 25
If DB8e No.1 doesn't get you ABC, you will need a VHF-High yagi for WMUR on real channel 9
If you want CBS you will need a VHF-Low antenna for WRGB on real channel 6 or a 3rd UHF antenna for WBZ.
Each antenna should have its own preamp and the combining should be done down below after the power inserters.
Antenna No. 1 should be connected to the antenna input of the TV, and antenna No. 2 should be connected to a separate tuner and its output connected to the aux input of the TV.
No, you can't combine the two antennas with a splitter in reverse. Well, you can, but you probably will not like the results.
