Old 12-Jan-2016, 1:05 PM   #19
shoman94
You should assume that more patience is required. A forum is not a medium for immediate responses.
You mentioned earlier that the antenna is above a metal roof.
As currently installed, is the antenna situated so that the incoming signals must cross the roof to arrive at the antenna or is the antenna mounted so that the signals hit it before crossing the roof?
Yes it goes across the metal roof. If you look at the attached image above you see where the antenna is placed. It is 5 feet above the peak of the roof attached by a gable end mount.
Just to reiterate though... I don't get these signal fluctuations without the PA-18.
EDIT: I don't expect immediate responses but I also don't see anyone else chiming in. My statement was based on limited responses that I have normally seen in other threads buy some very knowledgeable people as yourself. My post was in no way to insult anyone.
Another question, Can there signal fluctuations be the Pre-amp clipping?
