I'm assuming by the amount of responses here I'm shit out of luck?
You should assume that more patience is required. A forum is not a medium for immediate responses.
You mentioned earlier that the antenna is above a metal roof.
As currently installed, is the antenna situated so that the incoming signals must cross the roof to arrive at the antenna or is the antenna mounted so that the signals hit it before crossing the roof?
