Old 11-Feb-2010, 3:30 AM   #2
mtownsend
Originally Posted by seashipsink View Post
when I scan with the Visio all of the 4s have 2 copies of each listed in the guide but there is only a signal on 1 of each (the signal is reliable and rarely cuts out). The HVR-2250 on has only one copy of each but I barely get a signal and have to wiggle the antenna around to be able to (barely) watch the channel (it still cuts out often). Why might that be?
Hello and welcome!
There are actually two transmitters in your area (KXLY ch 13 and KXMN ch 9) that both map themselves to virtual channel 4. It sounds like your TV and your tuner card are handling this virtual channel collision in different ways. The TV is showing duplicate sub-channels (one set coming from real channel 13, and the other set coming from real channel 9). The tuner card is only showing one set, probably only from one of the real channels.
It looks like both of these transmitters are carrying identical content on their sub-channels (both transmitters are owned by Spokane Television, Inc.), so you don't need to receive both of them. It also looks like one of the signals is easier to receive than the other, so hopefully there's a way to manually delete RF channels from your TV and tuner card channel list so that the "bad" channel is no longer included in your lineup.
The local PBS station has recently switched over to a better signal and according to the website the channel has changed to 8.1. However when I scan with either tuner it still lists it as 7.1.
Yes, the original digital signal for KSPS was on real channel 8 with 21.6 kW of power. In mid 2009, they were granted a construction permit for a transmitter on channel 7 with 45.1 kW of power. As of today, I think they are completely transitioned to the new transmitter and have turned off the channel 8 transmitter for good.
The 8.x or 7.x virtual channel mapping is a simple software setting that they can change at any time. Apparently, they have forgotten or don't want to have their channel 7 broadcast remapped to virtual channel 8.x. Whether the channel show up as 7.x or 8.x is purely a cosmetic thing. The transmitter is definitely on real channel 7 either way.
And ever since the change my HVR-2250 has been unable to receive the channel at all.
I'm not sure how your HVR-2250 software works. Does it need to have a channel database (or access an online channel listing) to figure out which channels to tune to?
I know there have been issues with things like Windows Media Center Edition where the software references a channel database that might be out of date. People discovered the hard way that the software would not allow them to access some new transmitters until the master database was updated with the changes (which might take days, weeks, or months).
Does the HVR-2250 have a "memory" of channels that were successfully scanned in the past (kind of like the way TVs memorize channels from an auto-scan)?
Some converter boxes had a problem where they would not clear-out their channel memory on each auto-scan, and this created a problem around June 12, 2009 when lots of transmitters jumped around to new channel assignments. The only way to fix this on some of the boxes was to do a "double-rescan", which meant 1) disconnecting the antenna, 2) do a full auto-scan that should end up with zero results, 3) power cycle the device, 4) reconnect the antenna, and 5) do another full auto-scan to detect the new channels. On some boxes, the extra first scan was the only way to make the device forget about previously mapped virtual channels.
Any recommendations on these problems or on an antenna that may solve some of these would be much appreciated.
You seem to be getting all the channels that you would expect from an indoor antenna (channels listed in the "green" zone on your tvfool list). There are some duplicate channel conflicts that are adding a bit of confusion to the mix, but overall, I think your antenna is performing at about the right level.
