Okay, the new plot is not different enough to make any difference.
I have yet to ground the new RG6 cable to a grounding block. Also, the new RG-6 passes within 6" of the house's electric service feed. Could either cause the pixilation?
Shouldn't, unless the coax in use is defective.
It probably would be prudent to check with the station's engineering staff to see if their UHF translator is on the air.
