Looks like both Panasonic TV's are better. No noticeable dropouts but the problem channels listed above have large signal fluctuation problems. Some as much as 20%.
On my XBox One I'm still having the same problems but just slightly better. WCSH isn't cutting out anymore but the rest are about the same. This tuner was connected to the 3.5db drop of the splitter originally. Unfortunately I cannot see signal strength on the XBox.
EDIT: I installed a different splitter and the Panasonic's seem to be doing OK and I also switched to a different COAX going to my XBox since I already had 2 lines running there. Nothing has changed with the XBox.... with or without the splitter. So it looks like maybe the splitter was doing something but it did not stop the slight dropouts on the XBox. Is the PA-18 too strong?
