If you cannot receive WCYB's UHF 29 signal with a DB4e (or an ANT751R) with that report, something is very seriously amiss, whether it be the report is inaccurate or you've made some as-yet undiscovered mistake or have some system fault. A low band antenna shouldn't be needed based on your plot.
Verify your plot's accuracy by using the interactive tool and manually placing the marker on the antenna mounting location. Generate a new report at the correct height. Compare it to the first one for serious discrepancies. Post the new one if markedly different.
My first question when a reception location should be a slam dunk is always "what's in front of the antenna?" A forest, maybe?
