Old 11-Jan-2016, 9:19 PM   #1
rroellig
Low Band VHF WYCB
Hello All and thanks in advance for your time, patience and expertise
First; my signal analysis;
http://www.tvfool.com/?option=com_wr...5134dc112a763e
I am about to cut the cord and have done some prep and homework beforehand. I've looked at most of the prior posts for my area and low band VHF problems.
I'm setting up for three TV's. I subscribe to Netflix and Amazon Prime and will probably add Sling. I want to be able to view all the locals for zip 37659, Jonesborough, Tn.
With the exception of WETP-DT (real 41), every other network channel broadcasts from the Holston Mountain antenna farm approx. 25 miles away.
I have an RCA ANT751 and a DB4E left over from a previous home. I also have a Winegard LNA-200. I've not had much luck with the DB4E.
Here in Eastern TN, I installed the DB4E on my rooftop at 64 degrees compass (approx. 30' elev) and was able to receive CBS, ABC, FOX and Independent 49. I was not able to receive NBC (5 is pixelated, cannot receive 28 or 29 at all) either with or without the LNA-200 installed. I repeated the same with the ANT751 with basically the same results.
I then turned the ANT751 to 270 degrees compass and was able to receive WETP (PBS 41) at nearly 100% signal strength.
My plan is to keep the ANT751 pointed to WETP PBS and use a combiner for a combination low band VHF/UHF antenna set-up pointed at 64 degrees compass (Holston Mtn).
Please advise if this plan is reasonable. A recommendation for a low band VHF/UHF antenna would be greatly appreciated. I've looked at the CM3016 and the CM3018. I've also looked at the Winegard 7084. I've been known to subscribe to the "go big or stay home" theory but would like to stay reasonably small here (everyone else on the block are satellite subscribers). Again, thanks for all you do. RJR
rroellig is offline   Reply With Quote
