Rabbit73 ,
Yes - the AntennaCraft 10-Element Channels 7-13 Yagi Antenna is the only antenna that I have.
No - I am not running a pre-amp for the 175' coax run.
I did try and run a 30' run to another TV , with basically the same results for WYFF. Again, I did not use the Channel Master DVR+ tuner though, I used the tv's tuner.
Back in August 2015 , I thought I was going to have to do a jointenna with another antenna. Tower Guy suggested the Yagi antenna and the jointenna so I could get WLOS and the rest of the stations (CBS, FOX, NBC & PBS).
Once I installed the AntennaCraft 7-13 Yagi antenna though UHF - WYFF (NBC) , WHNS (Fox) came in perfectly without any issues, along with other VHF WSPA (CBS) , WNTV (PBS) and WLOS (ABC).
But now - not so much. I was SO happy for about 8+ months , all my stations that I wanted came in perfect all the time.
