Old 19-Jan-2011, 11:50 PM   #8
At this point we are all working with data that may or may not be representative of the real conditions at trijon04's location. From the posted TV Fool Report:
A report based on the actual site location may look similar or it may show dramatically different signal conditions.
I agree with John, a single combination antenna should easily serve in the situation represented in the first posted TVF report. The antenna I suggested would provide reception of the low VHF channels shown in the report. Still, the Antennas Direct combination should be quite capable (based on the original TVF report).
It sounds as if ADTech is willing to help sort out the difficulty using the Antennas Direct products. That's the logical next step. AD has shown a sincere willingness to help their customers, I would certainly recommend you let them have a chance to help you in this case.
I would be cautious about buying another antenna without first working with ADTech, and also running a TVF report based on the site address or coordinates.
