Old 11-Jan-2016, 3:48 AM   #13
shoman94
Ok now that I have spent a little time watching the channels with the family in bed.
My current setup: CS4V antenna aimed at 28DEG (TRUE) and 20' up and 5 feet above the peak of my metal roof.
2 RS FM traps, PA-18, PA-18 power inserter, 3 way splitter (5-1000mhz)
TVFOOL:
http://www.tvfool.com/?option=com_wr...513421e7b3a772
FMFOOL:
These issues only start after adding the PA-18 but is it tolerable (sort of) with the 2 FM traps. If I don't use the Pre-amp I cant split the signal to more than 2 tv's without issue and having the PA-18 also increases my weakest signal (23.1) by 5% to 10%.
This is all new to me. I just cut Directv! YAY! lol
6.1(Real-44)- Audio drops/skips randomly... not as bad as the others.
8.1(Real-8)- No issues
13.1(Real-38)- No issues
23.1(Real-23)- Audio drops/skips randomly every 5 to 15ish seconds (Sometimes video is effected but not pixel drops)
26.1(Real-45)- No issues
35.1(Real-35)- Audio drops/skips randomly every 5 to 15ish seconds (Sometimes video is effected but not pixel drops)
This evening,channel 51.1) has the most audio drops/skips.
51.1(Real-43)- Audio drops/skips randomly every 5 to 15ish seconds (Sometimes video is effected but not pixel drops)
