Thanks for the added height plots.
Indeed with elevation signal access does begin to improve at @ 75' At 100', it's even better. The upshot as you've already noted is how much effort are you willing to invest in this.
The hill behind your home sounds interesting however pushing 400+ ft. of cable will require considerations to signal loss. I might before I committed heavily, at that hill with minimal trees put your antenna of choice a few feet above ground and aim it at the weaker signals. See what the reception is with a shorter run of coax and a generator powering a TV.
Can you also adjust your plot slightly to reflect the hill location at 25, 50, 75 and 100'?
Cheers.
