Old 10-Jan-2016, 10:15 PM   #11
shoman94
Put the filter between the antenna and the amp, keeping all cabling before the amp to a minimum for best results.
So installing 1 fixed most except 2 channels... 6.x and 51.x
Then I installed 2.... 51.x is good but still fluctuates some signal wise... Channel 6.x is about the same... Maybe a touch better...
Then I installed 3.... 6.x still cuts out and pixelate, no real change. 51.x still fluctuates but no drop outs.
Any advice?
EDIT: Looks like WMEA radio station freq 90.1 is in the same exact direction as WCSH 6.1. Is that the culprit?
