Old 10-Jan-2016, 2:15 PM   #2
The PA18 is probably overloading from nearby FM stations. Other than that, it appears to be an appropriate amp for your situation. You need an FM filter or two, not a stronger amp.
Call any remaining Radio Shack stores in your area and ask them if they have any FM filters still on hand, catalog number 1500321 (15-0321). You have to call, the item is not on their website. The filter must be installed between the antenna and the amp and you'll need a short jumper cable to do that.
If you strike out with RS and don't mind a bit of a wait, fill out the contact form on our website (https://www.antennasdirect.com/custo...p-service.html) with your information and I'll get a filter and cable mailed out to you for free.
FYI, I tested that amp from Best Buy a while back. Its noise figure is so bad (> 7 dB) that there is no reason for the product to even exist, certainly not for antenna signals. It's really not a 4 dB amp, it's a 12 dB amp with an integral 4 port splitter (~8 dB insertion loss). I haven't tested the RCA amp shown, but it's probably a 15-18 dB gain amp with the same type of splitter and corresponding insertion loss.
Will the preamp work if I also install the passive splitter?
Yes, as long as you don't make the common mistake of installing a non-power passing splitter between the preamp and its power inserter. If your cabling layout requires the splitter to be installed in that cabling segment, a power-pass splitter must be used.
