Old 10-Jan-2016, 12:22 PM   #3
Tower Guy
Reception of the weaker group of stations will require nulling of the two close-in stations and an overload resistant preamp. The DB-8e is the best antenna for you. The side by side panels have a natural null at about 21 degrees off axis on channels 31 and 32. Your strongest stations are 24 degrees off axis. The trick will be to aim the antenna so that 31 & 32 are as weak as possible. You'll have a 3 degree aiming error on your desired stations, but that won't matter.
