Old 5-Jan-2016, 4:26 PM   #1
FinsToTheLeft
Reception issues - Local over Distant
Hi there,
I am having problems with reception and I am looking for some advice!
Tv Fool: http://www.tvfool.com/?option=com_wr...51342a830b5fe8
Antenna: Roof mounted C2V, no pre-amp
Distribution Amp: ChannelMaster 2 way
I have no problem with the local channels, but the Buffalo stations are an issue. CBS and PBS generally come in OK, but NBC/ABC/Fox are trouble at the best of times. I suspect the problem has to do that NBC is 75 miles away and only 5 degrees off of the CN Tower which is 3 miles away.
Any ideas would be appreciated.
Thanks in advance!
FinsToTheLeft is offline   Reply With Quote
