Tv Antennas and Reception
The mast will hold both antennas , mount the antennas 5 feet apart , one above the other , think in terms of strong and sturdy , not what can I get by with. The coax cables are RG-6. The splitters are passive splitters , passive means the splitters pass the signal through , active splitters amplify the signal. You are using passive splitters. You can find the remote control A/B antenna switches radio shack has them and you can find them at the links that I gave and you can type -- remote control a/b tv antenna switch -- in the google search box. All new Tv's have broadcast Tv digital tuners. If you have a older Analog tv then you will need a converter box. It will be helpful if you have some idea of how to install and connect it all up. Or if you know some one that -- truthfully -- knows what to do.
