Old 5-Jan-2016, 3:07 PM   #8
Would there be an alternative to the 91xg? I was looking at the specs and they are over 90" long.
As mentioned by Tower Guy, the DB8e might work as well as the 91XG, and it is a panel antenna that wouldn't stick out as far.
I was planning on installing setup on my garage wall pointing to 16 degrees.
The separate DB8e would need to be mounted in a location that shields it from the signals from 21 and 23 and have a clear path from the 22 transmitter without trees or other buildings in the way. Both panels of the DB8e must be aimed at 15 degrees true/358 degrees magnetic.
It would help if you can show us some photos of the mounting location, or send me the coordinates of the antenna location by PM so that I can look at the green signal lines on the tvfool interactive map browser.
I see a lot of trees in your area.
