Old 2-Jan-2016, 4:51 PM   #7
rockin1jr
Plenty
https://www.google.com/?gws_rd=ssl#q...+coaxial+balun
https://www.google.com/search?q=half...0nCIQQ_AUIBygC
The coax balun would replace the balun that comes with the antenna. With two antennas they must be connected the same way to keep the signals in phase. It's a lot of trouble for a slight reduction in loss, and keeping the coax ends waterproof is a problem. If I made one I would use a metal plate with 3 chassis F connectors like at the bottom of the 7777 housing and the coax would dangle down from the bottom. As Calaveras says in his diagram, the combiner is merely the 3 pieces of coax soldered together. The 1/4 wave matching line is just a piece of 50 ohm coax 1/4 wave long taking the velocity factor into consideration as is done with the balun. I would look for an F connector T adapter to do it.
https://www.google.com/?gws_rd=ssl#q...ctor+T+adapter
Thanks for the info rabbit73. I think my noise margins are too low to make a stacked antenna a huge helper, especially with only default 2.5 dB gain (we get a ton of rain storms here April - September, so any homemade combiner would certinally get wet).
I decided to go with 1 XG91 and see how it does at 20 feet with a rotor. I imagine it would out preform my HDB8X, solely on the fact that I replaced the default combiner on it with a ChannelPlus combiner, to not block out my local Fox on VHF. This has to be giving it some loss.
But thanks again for the help.
rockin1jr is offline   Reply With Quote
