Old 30-Dec-2015, 5:48 PM   #14
Originally Posted by welkin View Post
I have a ChannelMaster 7777. Also, I borrowed two different Winegard preamps to test. I have tested them in many different combinations (ie. FM trap on/off) to no effect.
That would have been good information to tell us up front.
As noted previously and based on your TVFool data, I cannot reasonably see any reason for optimism that you'll get the two stations from the northeast. KOLR *should* come in, but that's based only on the signal analysis which has a very wide margin for error in situations such as yours.
Your best bet for improvement is antenna elevation, as much as you can manage or afford to invest in an experiment.
Best of luck!
