Old 30-Dec-2015, 3:20 AM   #1
Shaunms
Do i have a chance?
Hi, in need of a little advice on reception. My tvfool report:
http://www.tvfool.com/?option=com_wr...b97d569f846710
The goal is to get CHAN-DT channel 22. Seeing that is a negative 3.9 dB i just don't know if i should even bother with spending $$ on a antenna. I bought a cheap digiwave 4 bay and was able to get 21, 27, 29, 23, 35, 19 and 24 with the antenna outside leaning against my fence. When aimed 15 degrees (me holding it) i cannot get CHAN channel 22 with the digiwave. I can mount an antenna properly on my roof aprox 20 feet up and have clear line at 16-17 degrees. Some trees at 15 degrees. Coaxial cable will be 30 feet max to tuner..do i have a hope with a proper antenna like the Db8e? Or is channel 22 just to weak?
Cheers
Shaun
Shaunms is offline   Reply With Quote
