Old 28-Dec-2015, 2:42 AM   #44
Irata
You should be able to get WHAS ABC from Louisville if the C5 is aimed that way.
I can't tell if that's normal because you have made many changes. I would need to see a diagram of what is connected to what and which way the antennas are aimed.
I said
So, which way did you do it?
I haven't actually combined them as of yet. Seems all the good weather days I've been busy with other commitments. The C5 test I did it started pouring about the time I started it.
Irata is offline   Reply With Quote
