I mounted my antenna a week ago and I picked approximately 15 deg. as a starting point. By the time I connected my system on 12/23 the roof was too icy to adjust the antenna.
There are many, many trees as you could see in the satellite image (your estimated location was correct, KBEM-FM is 0.8 miles away. With tree interference, is the best option to rotate/relocate the antenna until I get the best signal?
I think I'll start with an HLSJ and hope that will get me through until I can get back on the roof to rotate the antenna closer to 34 deg. Any preferred HLSJ manufacturers or locations/sites to by a HLSJ?
Thank you all for your assistance!
