since my signal analysis stated I should be able to pick up the major networks with indoor rabbit ears I thought an outside antenna would ensure I'd get the networks.
It *should*, however, the analysis cannot possibly anticipate every factor of your environment nor any mistakes that might be made by accident, usually due to seeking the "easy" installation spot.
why is only KMSP impacted?
Lousy luck, probably.
When does coax length become a problem?
Probably not, your signals are calculated to be "Very Strong".
Move the antenna a few feet using a temporary mount. Test. Repeat as needed until it works. Patience and persistence are virtues.
