Yeah I have 100 feet of cable at this antenna. The part under the house is quad shielded. The antenna is, I think, not high enough. It's sitting on a little stand which is lag-bolted to the face of the roof-eve. I'm about certain a pole mast system is in order. Yes there is one old metallic single-wide to my south. I will raise things up further and point south again to try.
thank you
Sam
