Old 12-Dec-2015, 11:37 PM   #29
DarkStar
DarkStar's Avatar
My Latest Antenna Solution
Based on my discussions here on the forum, I decided to try a Channel Master CM-4001 FLATenna with and without my small RCA pre-amplifier. I have just finished the frame I will be using to hold the CM-4001 so that I can rotate it through roughly 270 degrees of rotation, seeking out the strongest signals in the process. I have included some pictures.
The weather tomorrow promises to be rainy with intermittent thunderstorms so it should be a good test of the antenna's mettle!
I'll keep you all posted as the results are analyzed.
Illi qui male cogitat malum. Plus mali ei qui malum agit!
DarkStar is offline   Reply With Quote
