Old 12-Dec-2015, 4:23 AM   #4
kareemy
I just want to post a follow up. I had to order the FM Trap online and it just arrived a few days ago. In the meantime I tried the antenna outside. I mounted it on the roof in the best place I could find. Signal strength was equal or better on all channels vs in the attic. However after just about 30 minutes the pixelation and same symptoms appeared on KFDA.
I put the antenna back in the attic. I installed the FM Trap and placed some ferrite beads on the TV power cord and the coaxial cable. It has been three days and there have been no problems at all. Hopefully that solved it. Thank you, ADTech. It looks like it was definitely some sort of electronic interference.
kareemy is offline   Reply With Quote
