Old 8-Dec-2015, 2:19 AM   #39
Tim
Originally Posted by hsparks56 View Post
Found problem, it was a bad coaxial cable, seems like it worked when it wanted too. I did try aiming both panels in same direction works good and I think I'm going to keep them this way even though it works with them in different directions. The pictures are amazing!! What a difference from Cable. I am going with a rotor which ones would you recommend?
Thanks AD Tech, rabbit73!!!!
If it works good with the panels pointing in different directions, I don't understand why you would want to go to a rotor. For TV antennas, rotors are a pain the the a.., I mean rear...
