Old 6-Dec-2015, 9:45 PM   #37
hsparks56
Understood, but that is an important part of the test. It eliminates that possibility.
Without aiming both panels in the same direction, you don't really know if that is the cause of the problem or it is something else.
At this point all you know is that one antenna works and the other doesn't, but you still don't know why.
Found problem, it was a bad coaxial cable, seems like it worked when it wanted too. I did try aiming both panels in same direction works good and I think I'm going to keep them this way even though it works with them in different directions. The pictures are amazing!! What a difference from Cable. I am going with a rotor which ones would you recommend?
Thanks AD Tech, rabbit73!!!!
hsparks56 is offline   Reply With Quote
