WJLP is actually transmitting on RF channel 3. The FCC simply assigned them channel 33 to use as the number programmed into the data stream as an ID number. WJLP can't transmit on channel 33 because that channel is in use by WCBS.
Antennas to consider are the Winegard HD 7084P or Channel Master Advantage 45.
