Old 4-Dec-2015, 6:10 AM   #3
MattZuke
Originally Posted by 37pro View Post
Hello, I am interested in getting an hd antenna and would like a suggestion on which to buy.
HD antennas are a little bit of a misnomer. I'm sure you've seen it advertised but there is nothing HD or special about a TV antenna. In fact if you have an older one the odds are higher it'll pickup VHF-LO (2-6) as someone already pointed out.
WJLP - 3 (33) - METV
WPXO - 4 (34) - MundoMax
WKOB - 2 (42) - RetroTV (42.7)
I'm not 100% sure this database is accurate as WJLP claims the FCC ordered them to move to UHF. WKOB applied to be moved according to Wiki. WPXO looks up on rabitears.info as already being on UHF.
So if you want these two stations right away then as RickBB stated you'll need either an antenna that does VHF-Low or another antenna. If you don't care about these stations then don't worry about it.
MattZuke is offline   Reply With Quote
