Old 30-Nov-2015, 9:25 PM   #28
Jake V
Your original post said you had your Monoprice HDA-5700 pointed at 327 degrees magnetic.
On Nov 24th you said that laying it near the TV was better.
Today you said again that you have it pointed at 327 degrees magnetic.
Fox, This, ABC, CBS, NBC, CW and PBS are all at about 18 degrees magnetic.
What happens if you aim the flat side at 18 degrees?
Can you try this and report?
Try it holding it high, low and everywhere in between.
