Old 30-Nov-2015, 7:59 PM   #27
ChannelMaster FLATenna 35 (mod. CM 4001 HD) in the hopes THAT will improve my signal capturing ability.
Don't get your hopes up; I doubt that it will do any better than the RCA; it's just another flat antenna. I hope that you are buying antennas that can be returned, otherwise you are going to waste a lot of money.
Failing that, then I will have to escalate to the 50.00 CM antenna.
What model is that, this one?
http://www.channelmaster.com/SMARTen.../cm-3000hd.htm
The channels that you want are VHF-High channels, real channels 7-13. Flat antennas don't do very well with VHF-High signals.
The reason I subsume, that I was given this list of channels is because they are channels whose signals were detected by the combination of my extant antenna, pre-amp and TV tuner/dongle which were then fed into Window's Media Center software.
AFAIK, that list was based on your ZIP Code. WMC doesn't know that you are buying antennas that aren't very good for VHF-High channels. WMC doesn't know that you don't have an antenna for real channel 5. WMC doesn't know that your antenna is indoors.
https://www.google.com/?gws_rd=ssl#q...ls+from+zap2it
how to add missing channels to windows media center
https://www.google.com/?gws_rd=ssl#q...s+media+center
Did you work out an arrangement with ADTech by PM for a suitable antenna?
Are you willing to experiment with a DIY folded dipole antenna for your most wanted channels?
http://users.wfu.edu/matthews/misc/dipole.html
CH11, 198-204 MHz, center frequency 201 MHZ
5540/291 = 27.6 inches long for dipole
CH5, 76-82 MHz, center frequency 79 MHz
5540/79 = 70.1 inches
https://en.wikipedia.org/wiki/North_...on_frequencies
or would rather experiment with an antenna that you can return like the GE 24792 Attic Antenna, which Walmart has or
http://www.amazon.com/GE-24792-Anten...+attic+antenna
No guarantee it will work which is why you need to be able to return it.
I don't know the correct terminology - 'sub-channels'?
Correct
KCWI (f.k.a. KDMI) as channel 19 and its sub channels - which for reasons that are completely obscure to me, show up again as channel 23 and its sub-channels,
Click on this link
and click on KDMI
