Old 30-Nov-2015, 1:39 PM   #23
KKCI N S to Spotty/Pixelated
KCCI, real channel 8? Your antenna probably isn't very good for VHF-High channels.
IPTV Spotty/Pixelated
That's not an OTA callsign; we need a callsign, not internet
Do you have IPTV combined with OTA?
WHO Spotty/Pixelated
real channel 13; same comment as for KCCI
COMET (17) OK
Need a callsign; KDSM?
IPTV (21.1) N S
KCWI OK
KEFB N S
weaker; different direction
ION N S
KFPX ION 39; weaker, different direction. The antenna must be aimed at the transmitter. You will not be able to receive channels from all directions with only one antenna aim
WOI N S
that is on real channel 5, which is a VHF-Low channel; not gonna happen without a bigger antenna
This is what the digital TV signal analyzer app I found for my smart phone indicates the 'prime' signals are coming from.
You don't need a smart phone telling you what direction for the antenna aim, you need a tuner telling you signal strength, and signal quality as defined by Signal to Noise Ratio (SNR) and uncorrected errors.
This all leaves me scratching my head.
I'm also scratching my head. Why do you have IPTV mixed in with OTA callsigns?
Would I be better off with a better antenna OR would a more powerful pre-amp alone perhaps solve the problem?
Better antenna.
