Tv Antennas and Reception
If you choose not to install the 2 separate antenna systems. . You can install a one antenna system. The one antenna be a Winegard HD7698P with No amplifier. The HD7698P will be mounted on a rotor so as to turn the antenna to the two directions of 247 magnetic compass and 158 magnetic compass. The rotor is the Channelmaster CM 9521A
