Old 28-Nov-2015, 10:02 PM   #3
beflyguy
Rabbit73,
Hi and thanks for the help. I thought I was far enough away from all the transmitters that overloading would not be a problem but maybe you can tell from my signal analysis if this is correct. I did actually try without an amp and I received very little.
I don't know if this is a proper test but if I unplug the booster power now, I get no channels at all. Maybe I would have to take the amp out of the circuit to test properly?
Is there a way to tell the difference between a weak signal and an overload problem?
It seems like most of the lower channels are in the same direction other than 13 which is powerful enough to come in off angle. Do you think this is correct?
Would it help to angle the antenna over the trees?
Thanks again
Brian
beflyguy is offline   Reply With Quote
