Old 19-Jan-2011, 9:08 AM   #13
John Candle
Tv Antennas and Reception
Ok here is what to do to receive the digital channels --> plain and simple. Do not twist the information around and around and around until it's no information at all. Your location shows that if you will like to receive all the Digital Channels in the directions of magnetic compass 247 and magnetic compass 158 that you Need to install ----> 2 Separate antenna systems<----. You will Not connect the 2 separate antenna systems on to one coax at the same time. 2 separate antenna systems means 2 separate antenna systems. A Antennasdirect DB8 UHF antenna with No amplifier will be pointed at 158 magnetic compass. And a Winegard HD7698P antenna with No amplifier will be pointed at 247 magnetic compass. The reason I say 247 magnetic compass is because the Pending Applications Included show that digital channels 32 and 13 will be transmitting soon. At each Tv location will be remote control A/B antenna switch , http://www.antennasdirect.com , has the remote control A/B antenna switch , http://solidsignal.com , has the remote control A/B antenna switch , http://www.radioshack.com , has the remote control A/B antenna switch. Here are places to buy Antennas and etc.. http://www.solidsignal.com , http://www.3starinc.com , http://www.amazon.com
