Old 28-Nov-2015, 8:17 PM   #2
Welcome, beflyguy:
The 7777 preamp is easily overloaded by strong signals.
http://www.channelmaster.com/TV_Ante..._p/cm-7777.htm
KCPQ -37.5 dBm
7777 Max input level 15 dBmV = -34 dBmV
-37.5 dBm + 12 dB antenna gain = -25.5 dBm, overload
The 7778 would have been a better choice:
http://www.channelmaster.com/TV_Ante..._p/cm-7778.htm
7778 Max input level 34 dBmV = -15 dBm, OK
-25.5 dBm + 16 preamp gain = -9.5 dBm, just below tuner overload
Try your antenna without a preamp.
The antenna you selected is a high gain antenna which means that it has a narrow beamwidth, making it more difficult to aim; that's the tradeoff.
Trees are a problem for TV signals. Maybe there will be enough signal to get over them to be useful.
http://forum.tvfool.com/attachment.p...0&d=1448314548
