Old 28-Nov-2015, 5:33 PM   #2
Welcome, icunmypc:
The preamp of the Lava was probably overloaded by your strongest signals.
I suggest you try the Antennas Direct C2V antenna, no preamp.
The loops will pick up UHF channels, real channels 14-51. Aim north.
The dipole will pick up VHF-High channels 13, 11, and 9.
Use the TiVo diagnostics screen to monitor signal strength, SNR, and uncorrected errors to help you adjust the antenna.
You have some strong local FM signals that might interfere with TV reception.
http://www.fmfool.com/modeling/tmp/d...5/Radar-FM.png
If so, insert an FM filter in the coax.
