Old 27-Nov-2015, 6:08 PM   #28
hsparks56
I haven't used that combiner, but as near as I can tell the switch should be off if a preamp is used after the combiner. If you made a test with the switch on with no preamp but the power inserter on and powered, there is a chance that you have damaged the combiner or inserter or both.
I still don't understand; I would need to see a diagram of what is connected to what.
Thanks rabbit73, I check out all connections, combiner, preamp, etc. everything was good, it turn out to be my new db8e antenna, I had some second thoughts when I received it with the box partly open and taped??? I put my old UHF antenna up in place of it and everything worked. I am returning it for a replacement. Thanks again. Will see what the new one does when it comes in.
hsparks56 is offline   Reply With Quote
