Bex, Try running your channel scan again. Read each screen carefully. There should be one screen which asks you if you want to use an "Antenna" (sometimes it says "OTA") or "Cable". Make sure to choose "Antenna". With your TV Fool plot you should be getting some stations. [A stucco or aluminum siding house will block much of the signal. As will a window with e-glass or a metal screen.]
