Ok I suggest start off with one antenna pointed at WKOI-TV 39 at 109 degrees magnetic compass and you will receive the Cincinnati and Dayton channels. The antenna is the Winegard HD7695P and the preamp is a Winegard AP8700. Mount the antenna on the roof , with a Tripod mount or a Chimney mount or a peak of the roof Eave mount. With this one antenna system you will receive all the Networks except for ION Television that is in the opposite direction. You can then add a second antenna system at a later date. The second antenna system that points in the other direction for Indianapolis stations will also use a HD7695P and a AP8700. Here are places to buy antennas and etc.. http://www.solidsignal.com , http://www.3starinc.com , http://www.amazon.com
