Old 21-Nov-2015, 3:12 PM   #20
hsparks56
1. What are you using as a combiner?
2. Do you have a single continuous length of coax between the amplifier and it's power inserter?
3. Do you have a multimeter?
4. Did you test anything individually before integrating all the components or did you do an "install and hope"? Did you build the system one step at a time and test at each step?
The cable length between each antenna in this configuration is irrelevant.
Thanks ADTech for the quick reply:
1. I use this combiner: http://www.mcmelectronics.com/produc...3-E87D21A22E41
2. No it has a coax ground block in between.
3. Yes
4. No, No
hsparks56 is offline   Reply With Quote
