Old 21-Nov-2015, 1:44 AM   #10
- Regarding the tree, would it help to point the antenna up a bit (to point more "towards the sky" and "look above" the tree)? Or should antennas stay horizontal to the ground?
It might help, and is worth a try, but don't get your hopes up. Tilting your antenna up would be a custom modification. There is no magic antenna that will "see" through trees.
The next upgrade antenna would be the Winegard HD7694P, but what VHF channel is giving you a problem?
You didn't answer my question: Have you ever been able to receive WGEN?
