The antenna is currently mounted on the side of the roof. There is a pretty big tree a couple of houses down in the direction the antenna is pointing... Could that have such a huge effect to knock out that one channel?
The antenna is currently not grounded, would that affect the signal and make it worse?
I can currently get the usual CBS, FOX, NBC, ABC, Univision, UniMas, Telemundo, etc.... But no luck on Channel 8.1
Is my antenna appropriate for my distance to the towers?
