Old 19-Nov-2015, 5:00 PM   #9
Tim
Either way will work. It is often a matter of economics and the required equipment loads and wind loads on the structure. A large self supporting A shaped tower would be an example of support by "stiff steel rods" with a wide base reaching up to support a narrow top. It has forces acting in two major directions. A slim antenna tower supported by guy cables also has a wide base (the guy anchor bolts) and forces acting in two major directions (the tower itself is one and the guys are the other). Personally I have always found it very easy and inexpensive to just add three guys to a mast such as described. I use black dacron UV resistant rope as the guy material in many cases.
