Old 19-Nov-2015, 2:43 AM   #6
MikeBear
Originally Posted by GeorgeIoak View Post
I did have the antenna signal split to the TV and DIsh box. The TV was receiving signals fine but the Dish box was still missing 6.1. I did a channel scan on the Dish box and the scan setup page still showed 0 signal level but checking the actual channel revealed a picture (for the 1st time since the problem happened).
Going into and out of the setup screen on the Dish box brought a full signal level displayed on 6.1 so all is well. The only problem seemed to be something odd with the Dish box and channel 6.1.
Weird...
I think what's likely is when they messed with the coax cables, one didn't get tightened down quite right, or one of them got bent and "notched out" the signal a bit or something. Or even some corrosion which didn't rear it's head until the disconnects/reconnects. I've seen this happen. If you haven't manually run a "check switch", you should.
