Old 19-Nov-2015, 2:29 AM   #4
MikeBear
Originally Posted by GeorgeIoak View Post
I'll have to check if I have a direct feed into the TV. By "no signal" I mean when looking at the signal level meter in the Dish Network system it doesn't show any TV signal yet on the other channels I get a good signal level (more than 80%).
So, the 6.1 with no signal is the actual Dish satellite feed, OR, a yellow channel OTA feed that you scanned in on your Dish receiver, since some Dish receivers can also do OTA channels? If so, do a new OTA channel rescan on the Dish receiver
It's kinda hard to keep making suggestions, and only get little info replies if you don't lay out all your equipment and how it's hooked up... That would make it much easier to help you.
Can you post a screen pic of the Dish signal meter you are talking about?
