2 Antenna's, 1 Mast, Not Combined
I would like to mount 2 Low band VHF TV antennas on the same mast about 160 degrees directional difference. I need to monitor two TV stations. One in NY and one in PA. I will NOT be combining the signals. They will have separate coax runs and feed separate TVs.
The question is do I need to be concerned how far apart I mount the antennas. Is several inches ok, or do I need a specific minimum distance.
They will be identical antennas on the same pipe.
Thanks
Jim
