Old 17-Nov-2015, 7:32 PM   #2
Contact the station directly. This is not an antenna or a reception issue, so no worries there.
Sometimes the engineering department and the public relations department are not synchronized. Maybe a configuration option still needs to be flipped somewhere in their system.
Edit: The only story on their website from Sunday simply says they are now broadcasting their news programming in HD instead of SD, it makes zero mention of the resolution format.
I suspect you may have "mis-heard" what you thought you heard.
1080p is not a OTA broadcast standard,
Actually, 1080p IS part of the ATSC 1.0 broadcast standard but no broadcasters have chosen to use it. See ATSC A/53 part 4.
